Latest news: ---- MAN Cats II 12 - 14 + Activator FULL ---- CUMMINS INSITE 8.9 + CALTERM KEYGEN FULL ---- PETKA 8.3 - 10.2026 + VIN database 3.539.000 Full ---- TACHOSOFT MILEAGE CALCULATION SOFTWARE ---- MAN TG3 Q4.2021 MY23 WIRING DIAGRAM ---- R270 Programmer 1.20 Software FULL ---- WABCO TOOLBOX 14.9 FILES MEGA ---- TOYOTA + LEXUS TUNER SOFTWARE FULL ---- Current Database ECU Connection Diagrams ---- Airbag CrashKiller 7.8.4 + KG + Instruction ---- Mercedes Coding Programming Retrofix Tutorial ---- Multi PROG Script FILES ---- Ecu Data Sheet Helper Tool ---- Xentry Diagnostics Engineering Suite Full Fix ---- DAF Euro6 Service Repair Manual Pack ---- Freightliner Cascadia Gen5 Workshop Repair Manual ---- PTT 2.8.390 Tech Tool File MEGA ---- PTT 2.8.240 MFA Authorisation Plugin TOOL ---- MMI2G PATCH TOOL FULL ---- Top File Service Tuning ---- Wabco Diagnostic Software Full Package ---- Xentry Login Mode Switch Tool ---- DDT4ALL ECU FILES COLLECTION MEGA ---- BDM100 v1255 Galletto x64 + Installation Guide ---- Ksuite 2.25 Ktag 7.020 ECU Programming Full ---- Virtual Cockpit Plus Tool ---- Dashboard Service Tool 1.8 Mileage Correction Software ---- BMW PSdZData 4.62.12 Full Version ---- Case 621C 721C Loaders Service Manual PDF ---- Zenzefi Root And Backend Certificates 2027 ----
Multi Remover Tool - IMMO OFF - ORIGINAL
josepapel Offline
˙·٠•● Multi Remover Tool ●•٠·˙
Multi Remover Tool , 1.0.56.80 LAST VERSION
Original licensed software to be activated online.
Multi Remover Tool is a software capable of processing the files read by the engine control unit and modifying the status of the immobilizer, to carry out ignition tests in cars that have problems of failed starting due to a faulty immobilizer.
Through programmers already at your disposal you will read the file contained in the engine control unit and the MULTI REMOVER TOOL software, through an algorithm, will change the status of the immobilizer from active to deactivated.
All this to allow the operator to check the immobilizer system and verify its integrity.
ECU LIST :
FCA
BOSCH
EDC15C7 E2P 95P08 IMMO OFF
EDC15C7 E2P 95P08 VIRGIN
EDC15C7 FLASH 29F400 IMMO OFF
EDC16C8 E2P 95160 VIRGIN
EDC16C39 E2P 95640 VIRGIN
EDC16C39 E2P 95640 IMMO OFF HYBRID | FIAT SEDICI
EDC16C39 E2P 95640 VIRGIN HYBRID | FIAT SEDICI
EDC16C39 E2P 95640 VIRGIN HYBRID | 0281012144
EDC16C39 E2P 95640 VIRGIN HYBRID | 0281012309
EDC16C39 FLASH IMMO OFF
EDC17C49 FLASH IMMO OFF
EDC17C69 FLASH IMMO OFF
EDC17CP52 FLASH IMMO OFF
ME3.1 FLASH 29F400 IMMO OFF
          0261204949
          0261206070
ME7.3.1 FLASH IMMO OFF
ME7.3H4 FLASH 29F400 IMMO OFF
          0261204983
          0261206980
          0261206983
          0261207490
          0261207901
ME73H4 E2P 95P08 VIRGIN
ME17.3.0 FLASH IMMO OFF
ME7.6.3 E2P 95080 VIRGIN
ME7.9.10 E2P 95160 VIRGIN
MARELLI
16F MCU 68HC11F1 IMMO OFF
18F MCU 68HC11F1 IMMO OFF
49F.B9 E2P 95040 IMMO OFF
4AF E2P 95160 IMMO OFF
4AF E2P 95160 VIRGIN
4EF E2P 25080 IMMO OFF
5AF E2P 95160 IMMO OFF | HW>100
5AF E2P 95160 VIRGIN | HW>100
5NF E2P 95160 VIRGIN
5NF E2P 95160 IMMO OFF
5SF E2P 95160 VIRGIN
59F E2P 95080 IMMO OFF | HW<100 !Not work on cars equipped with BSI Delphi
59F E2P 95160 IMMO OFF | HW>100 !Not work on cars equipped with BSI Delphi
59F E2P 95080 VIRGIN | HW<100 !Not work on cars equipped with BSI Delphi
59F E2P 95160 VIRGIN | HW>100 !Not work on cars equipped with BSI Delphi
5SF8 FLASH ST10F296 VIRGIN
5SF9 E2P 95160 IMMO OFF HYBRID | Does not work on ECU Part Number 51847332
6JF FLASH IMMO OFF
6JF E2P 95320 VIRGIN
6F3 E2P 95320 VIRGIN HYBRID
6F3 FLASH IMMO OFF
6F3 FLASH IMMO OFF V2
8DF FLASH IMMO OFF
8DF E2P 95640 VIRGIN
8F2 FLASH IMMO OFF
8F2 E2P 95640 VIRGIN
8F3 FLASH IMMO OFF
8F3 E2P 95640 VIRGIN
8GSW FLASH IMMO OFF
8GSW E2P 95640 VIRGIN
9DF FLASH IMMO OFF
9DF E2P 95128 VIRGIN
9GF FLASH IMMO OFF | 9GF.DK not Supported
9GF E2P 95640 VIRGIN
MM10J E2P VIRGIN
LUCAS
DCU3F E2P AT25080 IMMO OFF HYBRID
VISTEON
DCU102 FLASH VIRGIN | Kline
BMW
BOSCH
EDC1.3.1 E2P 93C46 IMMO OFF
EDC15C4 FLASH 29F400 IMMO OFF
EDC15C4 FLASH 29F400 IMMO OFF HYBRID | 009079914 0281010314 351761 | 0281001830 1037350667
EDC16C31 FLASH IMMO OFF
EDC16C35 FLASH IMMO OFF
EDC16C35 E2P 95640 VIRGIN | Tested 0281012191
EDC16CP35 FLASH IMMO OFF
EDC17C06 FLASH IMMO OFF
EDC17CP02 FLASH IMMO OFF
EDC17CP09 FLASH IMMO OFF
SIEMENS / CONTINENTAL
MS41 FLASH 29F200 IMMO OFF
MS42 FLASH 29F400 IMMO OFF | Tested 0110AD 0110C6 0110C7 0110CA
MS43 FLASH 29F400 IMMO OFF | Tested 430037 430056 430066 430069
CHEVROLET
BOSCH
Continental D52 FLASH IMMO OFF HYBRID | Tested Spark 25182025 5WYLKLLA 96958816
ACDELCO
E84 FLASH + E2P IMMO OFF HYBRID | Tested Onix 12685506 24588182
DELPHI
MT80.1 FLASH + E2P IMMO OFF HYBRID | Tested Cruze 25184124 25181828 JAAL AAJ1
MT80 FLASH IMMO OFF
IVECO
BOSCH
EDC16C8 E2P IMMO OFF HYBRID | Tested 0281011228
EDC17C49 FLASH IMMO OFF | MEDC17_PROTOCOL
EDC17C49 FLASH IMMO OFF | DISTINCT_PROTOCOL Tested 0281035639
EDC17C69 FLASH IMMO OFF | Tested 0281032557
EDC17CP52 FLASH IMMO OFF | The protocol works on vehicles registered before 2014
EDC17C1 E2P 95640 IMMO OFF | The vehicle may not accelerate
EDC7UC31 E2P 95640 IMMO OFF | The vehicle may not accelerate
FORD
BOSCH
MSA15.X E2P 24C02 IMMO OFF
EDC16C34 E2P 95160 IMMO OFF | Use PSA Protocol
EDC17C10 FLASH IMMO OFF
HYUNDAI & KIA
BOSCH
EDC15C7 E2P IMMO OFF HYBRID | Tested Santa Fe | Tested Accent 0281010619
EDC15C7 FLASH IMMO OFF | HYUNDAI Getz | Tested 0281011260
EDC15C7 FLASH IMMO OFF | KIA Sportage | Tested 0281012099
EDC16C39 E2P IMMO OFF 95320 V1
EDC16C39 E2P IMMO OFF 95320 V2
EDC17C08 FLASH IMMO OFF
EDC17CP14 FLASH IMMO OFF
EDC17C57 FLASH IMMO OFF
M 7.9.0 FLASH IMMO OFF | HYUNDAI Getz | Tested 0261206465
M 7.9.X FLASH IMMO OFF | KIA RIO
ME17.9.11.1 FLASH IMMO OFF
ME17.9.21 FLASH IMMO OFF
ME17 FLASH IMMO OFF
LAND ROVER
BOSCH
EDC17CP11 FLASH IMMO
YM ROVER
LAND ROVER E2P 93C46 IMMO OFF
LAND ROVER E2P 93C66 IMMO OFF
MAHINDRA
BOSCH
EDC17C53 FLASH IMMO OFF
EDC17C55 FLASH IMMO OFF
EDC17C63 FLASH IMMO OFF
MITSUBISHI
MITSUBISHI ELECTRIC
(CZECH) MPC ALGO IMMO OFF !Tested Mitsubishi Colt A1351501979 1860A301 E6T42484 H3ZE
NISSAN
BOSCH
EDC15 E2P 24C04 IMMO OFF
MSA15.6 E2P 24C02 IMMO OFF HYBRID | Tested 0281001550 NISSAN TERRANO
M1.9.5 E2P VIRGIN & IMMO OFF HYBRID | Tested MICRA K11
EDC17C42 FLASH IMMO OFF
EDC17C11 FLASH IMMO OFF
HITACHI
MECM-T935 E2P IMMO OFF HYBRID | Tested NISSAN TERRANO
MINI
BOSCH
EDC17C41 FLASH IMMO OFF
MEV17.2 FLASH IMMO OFF
OPEL / GM
BOSCH
EDC16C39 E2P 95640 IMMO OFF | Tested 0281012869
EDC17C18 FLASH IMMO OFF | Only 1.3MJT
EDC17C19 FLASH IMMO OFF | Only 1.3MJT
MEV17.8 FLASH IMMO OFF
M1.5.4 E2P 24C02 IMMO OFF
MARELLI
6JO E2P 95320 VIRGIN
6JO E2P 95320 IMMO OFF HYBRID
6O2/ E2P 95320 VIRGIN
6O2 E2P 95320 IMMO OFF HYBRID
6O3 E2P 95320 VIRGIN
6O3 E2P 95320 IMMO OFF HYBRID
ACDELCO
E37 FLASH IMMO OFF
E83 FLASH IMMO OFF
PINCODE
BOSCH EDC15M1 E2P 24C04
BOSCH EDC16C9 E2P 95160/95640
BOSCH EDC16C39 E2P 95640
BOSCH EDC17C18 E2P
BOSCH EDC17C19 E2P
MARELLI 6O2 E2P 95320
DASH OPEL CORSA D E2P 35080
ACDELCO E83 FLASH FLASH
PORSCHE
BOSCH
EDC17CP44 FLASH IMMO OFF
PSA
BOSCH
EDC15C2 FLASH IMMO OFF
EDC15C2 E2P IMMO OFF
EDC16C3 E2P 95160 95320 95640 IMMO OFF
EDC16C34 E2P 95160 IMMO OFF | Does not work on vehicles with PSA systems 0281013331
EDC17C60 FLASH BDM TPROT
EDC17C60 FLASH IMMO OFF
EDC17CP11 FLASH IMMO OFF
MEV17.4 FLASH IMMO OFF
MP 7.0 E2P 93C46 IMMO OFF HYBRID | Tested 0261204234 PEUGEOT 406
ME 7.4.4 E2P + FLASH IMMO OFF HYBRID | Tested Peugeot 206
M 7.4.4 E2P IMMO OFF HYBRID
ME 7.4.5 E2P IMMO OFF | It does not work on HW 0261208491
SID208 E2P TC1797 VIRGIN
SID801 E2P 93C56 IMMO OFF
SID801 E2P 93C56 VIRGIN
SID801A E2P 93C56 IMMO OFF
SID802 E2P 93C56 IMMO OFF
SID803 E2P 95320 IMMO OFF
SID803A E2P 95320 IMMO OFF
SID804 E2P 93C56 IMMO OFF
SID806 E2P 93C56 IMMO OFF
VALEO
J34P E2P 95160 IMMO OFF
J34P E2P 95160 IMMO OFF HYBRID
J34P E2P 95160 VIRGIN HYBRID
V34.1 E2P 95160 95320 IMMO OFF
V34.2 E2P 95160 95320 IMMO OFF
V34.3 E2P 95320 IMMO OFF
VD46.1 E2P 95128 25128 IMMO OFF
VD46.11 E2P 95128 25128 IMMO OFF
V46.21 E2P 95128 25128 IMMO OFF
MARELLI
6LPB FLASH IMMO OFF
6LP2 FLASH VIRGIN
1AP.XX FLASH 28F512 IMMO OFF HYBRID
DELPHI
DCM3.4 E2P 95320 IMMO OFF
DCM6.2 E2P 25LC256 IMMO OFF
DCM6.2A E2P 25LC256 VIRGIN HYBRID | Required Telecoding
VISTEON
DCU102 FLASH VIRGIN
PINCODE
BOSCH EDC17C10 E2P
BOSCH EDC17C60 E2P
VALEO J34P E2P
SIEMENS SID804 E2P
SIEMENS SID807 E2P
DELPHI DCM6.2 E2P
RENAULT
BOSCH
MSA15 E2P 24C02 IMMO OFF HYBRID | Tested 0281001969
EDC17C42 FLASH IMMO OFF | Not work on key-card vehicle
SIRIUS 32/34 FLASH 29F200 KLINE
SIRIUS 32N FLASH 29F200 with CAN
SIRIUS 32N FLASH 29F200 HYBRID
-------------- Tested S110130114B 8200064017 8200044437 1.2 8V M
-------------- Tested S110138000B 8200087723 8200044437 1.6 16V M AC
-------------- Tested S110138000B 8200059086 8200044437 1.4 8V M AC
-------------- Tested S110130334A 8200061281 8200044437 1.4 8V M AC
SIRIUS EMS3132 FLASH VIRGIN
SIRIUS EMS3132 FLASH IMMO OFF
SIRIUS EMS3134 FLASH VIRGIN
LUCAS
DCU3R E2P 95080 IMMO OFF HYBRID
MARELLI
5NR2.C5 E2P 95160 HYBRID
DELPHI
DCM1.2 E2P VIRGIN
DDCR E2P 95080/25C080 IMMO OFF | DDCR TRW ECU it can't be made IMMO OFF
DDCR E2P 95080/25C080 VIRGIN
YM ROVER
SUZUKI
BOSCH
EDC16C39 E2P IMMO OFF HYBRID
EDC16C39 E2P VIRGIN HYBRID
SIEMENS
SID801 E2P 93C56 IMMO OFF HYBRID | Tested SUZUKI VITARA 2.0 HDI 5WS40035A-T HWZY34027299
SID801A E2P 93C56 IMMO OFF HYBRID | Tested SUZUKI VITARA 2.0 HDI 5WS40160B-T HWZY34027526
TRUCKS
BOSCH
EDC MS6.X E2P 24C16 IMMO OFF
EDC7XX E2P 95640 (EDC7, EDC7C1, EDC7C3, EDC7C32, EDC7C4, EDC7EU31, EDC7UC31) VIRGIN
EDC7C3 E2P 95640 IMMO OFF | Tested MAN 0281020056
EDC MS6.2 E2P 24C16 VIRGIN
EDC MS6.2 E2P 24C16 IMMO OFF
VAG
BOSCH
EDC15V E2P 24C02 IMMO OFF
EDC15M E2P 24C02 IMMO OFF
EDC15V E2P 24C04 IMMO OFF
EDC15VM+ E2P 24C04 IMMO OFF
EDC15.xx FLASH 29F800 IMMO OFF
EDC15P/EDC15P+ FLASH 29F400 IMMO OFF
EDC15P+ E2P 24C04 IMMO OFF
EDC16xx E2P 95320 IMMO OFF
-------------- Checksum_1Byte = Variant1
-------------- Checksum_2Bytes = Variant2
-------------- Checksum_None = Calculate the Checksum before writing
EDC17xx FLASH IMMO OFF
EDC17C46 FLASH IMMO OFF
EDC17C54 FLASH IMMO OFF
EDC17C64 FLASH IMMO OFF
EDC17C74 FLASH IMMO OFF
EDC17CP04 FLASH IMMO OFF
EDC17CP20 FLASH IMMO OFF
EDC17CP54 FLASH IMMO OFF
EDC17U01 FLASH IMMO OFF
EDC17U05 FLASH IMMO OFF
MED17xx FLASH IMMO OFF
ME17.5.2 FLASH IMMO OFF
ME17.5.24 FLASH IMMO OFF
MED17.1 FLASH IMMO OFF
MED17.1.27 FLASH IMMO OFF
MED17.5 FLASH IMMO OFF
MED17.5.1 FLASH IMMO OFF
MED17.5.2 FLASH IMMO OFF
MED17.5.20 FLASH IMMO OFF
MED17.5.21 FLASH IMMO OFF
MED17.5.25 FLASH IMMO OFF DEDICATED PROTOCOL
MED17.5.5 FLASH IMMO OFF
ME 7.1 E2P 95040 IMMO OFF
ME 7.5 E2P 95040 IMMO OFF
ME 7.X.X E2P 95040/95160 IMMO OFF
MED 9.1 E2P 95160 IMMO OFF
MED 9.5.10 E2P 95080 IMMO OFF
MP 9.0 E2P 24C02 IMMO OFF HYBRID
BOSCH SPECIAL FUNCTIONS
EDC17 TPROT OFF
MED 9.1 LOCK OBD READ
MARELLI
MM7GV.xx E2P 95320 IMMO OFF
4MV.xx E2P 95080 IMMO OFF
4HV.xx E2P 95080 IMMO OFF
4LV.xx E2P 95080 IMMO OFF
4AV.xx E2P 95040 IMMO OFF
4CV.xx E2P 95040 IMMO OFF
4TV.xx E2P 95080 IMMO OFF
SIMOS
5WP4 3PE E2P 93C76 IMMO OFF | Tested 03E906033 5WP4016303
5WP4 3PA E2P 93C76 IMMO OFF
5WP4 3.3A E2P 93C76 IMMO OFF
5WP4 9.1 E2P 93C86 IMMO OFF
5WP4 2.1 E2P 93C56 IMMO OFF
5WP4 7.1 E2P 93C56 IMMO OFF
5WP4 7.1A E2P 93C56 IMMO OFF
5WP4 2.3D E2P 93C56 IMMO OFF
18.1 FLASH IMMO OFF
VOLVO
BOSCH
EDC17CP22 FLASH IMMO OFF
SANGYONG
DELPHI
DCM3.2AP E2P 95160 IMMO OFF
DCM3.2AP E2P 95320 IMMO OFF
TOYOTA‍
BOSCH
EDC17CP07 FLASH IMMO OFF
EDC17CP37 FLASH IMMO OFF
EDC17C60 FLASH IMMO OFF | Tested on PSA implant
DENSO
GENERATION1 MCU IMMO OFF NEC76F00XX
GENERATION2 MCU IMMO OFF Renesas D76F0
GENERATION3 MCU IMMO OFF Renesas R7F7012XX
DUCATI
MARELLI
5AM.xx HW610 FLASH IMMO OFF
5AM.xx HW103 FLASH IMMO OFF
59M.xx FLASH IMMO OFF
MAN
BOSCH
EDC7C3 E2P 95640 IMMO OFF | Tested 0281020056
SCANIA
BOSCH
JEEP
BOSCH
JAGUAR
DENSO
079700-8XXX E2P TC97101P IMMO OFF
CHINA
BOSCH
ME7.9.7 FLASH IMMO OFF | Greatwall Changean Cherry Haima Dongfeng
MOTO GUZZI
MARELLI
5AM MCU ST10F168/ST10F269 IMMO OFF VIRGIN
59M MCU ST10F168/ST10F269 IMMO OFF VIRGIN
APRILIA
MARELLI
5DM MCU ST10F168/ST10F269 IMMO OFF VIRGIN
DUCATI
MARELLI
5AM FLASH HW103/HW610 IMMO OFF
59M FLASH HW103/HW610 IMMO OFF
PIAGGIO
MARELLI
MIU1.EO FLASH IMMO OFF
__
After the purchase, the software to download, install and activate the license online will be sent to your email.
The software is original with license to be activated online.
 License valid for One PC with personal username and password.
◦•●◉✿ Lifetime license ✿◉●•◦.
Free updates forever.
Price. 275 €uro
_
If you want it, contact me..
